Drivetrain Gearbox, Diffs & Driveshafts etc
Slipping out of 5th Gear
Old 19 January 2003, 04:26 PM
fanatik
fanatik's Avatar
Unhappy
Hi All,
Within the last week my car has started to jump out of 5th gear - I have only noticed it on the motorway and it appears to be after I lift off. When I go to put the power back on, it just revs highly until I engage the gear again. Its happened quite a number of times now and I am starting to worry...
Does anyone have any ideas as to what could be wrong?
The warranty expires in a month - so I have to get it sorted soon!
Thanks,
James.
Old 19 January 2003, 04:49 PM
Neil Smalley
Neil Smalley's Avatar
Post
There's a bolt in the gearbox that sometimes works loose. It's a known problem, but requires the gearbox to be rebuilt. Get it sorted before the warranty expires.
My old MY00 had it and the car was away for 2 days while they did it.
Old 19 January 2003, 05:44 PM
UkLegacyT
UkLegacyT's Avatar
Post
thought it was the big nut on the end of the shaft, next to the fifth gear ring
you only have to open the box and tighten it.
ian
Old 19 January 2003, 06:25 PM
fanatik
fanatik's Avatar
Smile
Thanks guys - I will take it back to the dealers asap
James.
Old 19 January 2003, 09:39 PM
Neil Smalley
Post
UK,
When mine went it was a gearbox rebuild job. Basically they had to take the gearbox apart to get to the bolt, fix it and then put it back together
Old 20 January 2003, 10:52 AM
fanatik
fanatik's Avatar
Post
I've just spoken to Lancaster Pangnbourne. They said basically it would need a 5th gear modification, by that they meant it had to be replaced!
Mine is also a MY00.
James.
Old 20 January 2003, 10:54 AM
UkLegacyT
UkLegacyT's Avatar
Post
sorry Neil, thought you meant it needed a rebuild ie new gears etc.
im gonna do my mates sti 5 asap, its doing the same thing, pops out of 5th when releasing throttle
cheers
ian
Old 22 January 2003, 02:17 PM
fanatik
fanatik's Avatar
Post
Just to confirm - took it along to Lancaster's yesterday - was worried that they wouldn't be able to spot the problem as it only happened once on the way up there (80 miles). But one of the guys there took it out for a spin and instantly found the problem. It is now booked in to have a new 5th gear.
To test, put it in 5th at a relatively low speed (30-40) and accelerate hard for a short while, then lift off and accelerate again... drops straight into neutral if there is a problem.
Cheers,
James.
JimBowen
ICE
02 July 2023 01:54 PM
crookedvulture
28 September 2015 07:20 PM
Quick Reply: Slipping out of 5th Gear
