Wheels, Tyres & Brakes
HELP! Torque settings: Caliper bolts and wheel nuts?
Old 21 January 2006, 01:00 AM
v8voodoo
v8voodoo's Avatar
Default HELP! Torque settings: Caliper bolts and wheel nuts?
Hi All,
I would do a search, but......
So, can anyone please let me know the torque setting for the front caliper bolts and the wheel nuts so I can change my discs and pads tomorrow...?
Not that bothered for the wheel nut settings as I can feel when they're right, but would like the setting for the caliper mounting bolts as they're errrr.... quite important..!!
Cheers in advance,
Nige.
Old 21 January 2006, 08:28 AM
stockcar
stockcar's Avatar
70ft/lb for the caliper bolts and 65ft/lb for the wheel nuts...................
do not be tempted to do the wheel nuts tighter as damage can occur to the threads
alyn
Old 21 January 2006, 02:20 PM
v8voodoo
v8voodoo's Avatar
Alyn,
Not only do you supply me with Pagid pads at a great price and at the speed of light, but you pop up on here with top information for me.
I know where where I'm going for any more parts....
Top marks from me.
Nige.
Old 21 January 2006, 07:13 PM
stockcar
stockcar's Avatar
we do try..............................
Old 25 January 2006, 01:12 AM
v8voodoo
v8voodoo's Avatar
What a difference in just new discs (Subaru standard) and these Pagid 4-2-1 pads..!!! And I haven't even used them properly yet, which leads me on to......
What would the correct bedding in procedure be for the above combo...??
I've read a few suggestions on the web of lies, which include several light pedal uses from 95mph down to 65 mph and three or four medium/hard uses from 110mph down to 65mph both with cooling off in between and light use at the end of each run. Now, as I don't have a private test track, how the hell do I bed 'em in..? Or do I really need to use my private test facility at 2am..?!
Cheers,
Nige.
Old 25 January 2006, 07:56 AM
Gear Head
Gear Head's Avatar
Just drive carefully for the first 500 miles or so. I would avoid heavy stops, especially from anything over 70mph. Discs tend to warp when they get to hot and this applies even more so when they are new.
Old 25 January 2006, 08:19 AM
stockcar
stockcar's Avatar
the RS4.2.1 comes partly pre-bedded out of the factory and as such needs only around 150-200miles max (combined with the discs) of reasonable driving..................
don't molly coddle or they will never bed properly, but no ABS type stops either!!
DO NOT be attempted to use the aggressive bedding process with RS4.2.1 as this is only for more competition orientated materials and definately will cause problems with discs...................
you always need to bed the components you have properly (in the manufacturers spec) rather than some posts on the web that suggest that every material/scenario is identical..................
hope this helps, alyn
Old 25 January 2006, 09:42 PM
v8voodoo
v8voodoo's Avatar
Oi, Alyn......
Nice one. Thought the process I found via a Google search seemed a bit extreme.
Thanks again for the excellent advice.
Nige.
Harley87
23
11 December 2015 09:54 AM
blockhead
19
07 November 2015 11:50 PM
IanG1983
22 September 2015 09:47 PM
ethanrob
Wheels And Tyres For Sale
15 September 2015 03:03 PM
Quick Reply: HELP! Torque settings: Caliper bolts and wheel nuts?
