sigma key fob broken+no pin code
Old 07 February 2008, 01:13 PM
\\shorty//
\\shorty//'s Avatar
Default sigma key fob broken+no pin code
battery connector on fob is broken and i have misplaced pin code. how can i get the car to start?
Old 08 February 2008, 12:12 PM
urban
urban's Avatar
You've had it I'm afraid.
You can reset the pin with these instructions, but you need the fob working to do so.
However, its handy to remember these anyway.
Provided that you can disarm the system with a working Radio Key or the current PIN, then you can re-set the 4-digit PIN to one of your own choosing yourself, using the keypad, at any time.
If you do not have the current PIN, then option A is your best solution. However if you do not have a working Radio Key, then you will have to use option B and obtain the systems PIN code from Subaru (UK). Your dealer can obtain this for you if you can provide proof of ownership and the alarm systems 16-digit serial number.
A. Using a working Radio Key:
- Arm and then Disarm the system using a working Radio Key.
- Within 30 seconds of disarming, type into the keypad- *17856*92*wxyz*wxyz# (where wxyz is your new PIN code)
- Arm the system with the Radio Key
- You should now be able to disarm the system using the new PIN code
B. Using the current PIN Code (if a working Radio Key is not available):
- Arm and then Disarm the system using the current PIN
- Within 30 seconds of disarming, type into the keypad- **abcd*92*wxyz*wxyz# (where abcd is your current PIN code and wxyz your new PIN code)
- You should now be able to arm and disarm the system using the new PIN code
When using the keypad always observe the following points:
- The PIN number should not be entered too quickly or too slowly - when a digit has been pressed the small LED built into the keypad will illuminate briefly as confirmation and only then should the next digit be entered.
- If an incorrect digit is pressed or the delay between entering digits exceeds10 seconds, then the LED above the keypad will flash rapidly and the PIN attempt should be abborted and started again after 30 seconds.
- Due to the small size of the keypad some users may find a rubber tipped pencil easier to use. DO NOT use the sharp tip of a ball point pen etc, or press excessively hard on the keypad as this will only damage the membrane and cause a digit to remain pressed, causing a continual incorrect PIN.
- The keypad allows only THREE PIN attempts and then will "Lock Up" if an incorrect number is entered a third time. This is a security feature to prevent random PIN attempts disarming the system.
Darrell@Scoobyworx
Trader Announcements
26
30 January 2024 01:27 PM
Sam Witwicky
17
13 November 2015 10:49 AM
Quick Reply: sigma key fob broken+no pin code
