Non Scooby Related Anything Non-Scooby related
How to siphon petrol out of a car?
Old 02 July 2010, 09:35 PM
^OPM^
^OPM^'s Avatar
Default How to siphon petrol out of a car?
Ok here goes-soon i will be trading in an old mk2 mondeo for a new car-now as car being 12 year old aint worth much i dont really wanna let it go to dealer with about £50 worth of petrol in it-can i just remove pipe from either inlet or outlet side of fuel filter and place over a petrol can and then turn ignition to position number 2 and will this start fuel flowing out of pipe?
Old 02 July 2010, 10:47 PM
dpb
dpb's Avatar
Talk about tight
Old 02 July 2010, 10:56 PM
scoobyvirgin
scoobyvirgin's Avatar
You want it on the return pipe, used to do this on Vectra hire cars, might not be the same on the Mondeo, just turn the car over and let it run. Or as above, tube and suck!
Old 02 July 2010, 10:58 PM
scoobyvirgin
Oops, I mean the return pipe that's usually above the tank. Usually accessible from under the rear seat.
Old 02 July 2010, 11:06 PM
SiPie
SiPie's Avatar
Suck on bit of hosepipe until you gag on taste of petrol, then vacuum will do the rest as you pour it downwards into your jerry can.
Quite right too..... Give the rip off dealers **** all
Old 02 July 2010, 11:34 PM
john banks
john banks's Avatar
The potential chemical pneumonitis will cost you a lot more than £50.
Old 03 July 2010, 01:04 AM
tathan
tathan's Avatar
i like to take the fuel line to the filter off and turn ignition on. don't like the taste of unleaded.
Old 03 July 2010, 07:48 AM
Jamie
Super Muppet
Jamie's Avatar
Originally Posted by hutton_d
If you're 'ard you use a plastic pipe and suck .....
Dave
Old 03 July 2010, 08:58 AM
David Lock
David Lock's Avatar
I used to use the tube and suck approach and with a clear pipe you could avoid getting a mouthful although fumes were probably a bad thing. Best not to smoke immediately afterwards
Years ago I bought a little suction pump that fits on the end of an electric drill and will do the job. Don't know how much they cost but can't be a lot. dl
Old 03 July 2010, 09:44 AM
Leslie
Leslie's Avatar
Dave
You only do that and get it wrong the once!
Les
Old 03 July 2010, 09:48 AM
dpb
dpb's Avatar
I *thought* most cars had anti siphoning measures built in nowadays ....
thats why the POS went straight for my tank when they couldnt get anything thro the filler
Old 03 July 2010, 09:56 AM
spender(again)
spender(again)'s Avatar
I hope you've got a big jerry can for £50 of fuel..................
Old 03 July 2010, 10:04 AM
dpb
dpb's Avatar
lol
Old 03 July 2010, 10:31 AM
hodgy0_2
hodgy0_2's Avatar
try on www.pikey.com
they will know
Old 03 July 2010, 11:22 AM
LEUVEN
LEUVEN's Avatar
they will know
LMAO
Old 03 July 2010, 11:52 AM
ALi-B
Moderator
ALi-B's Avatar
The pump only runs for 2-3 second when the engine is not turning.
You'll need to bridge teh fuel pump relay, or feed 12v straight to the pump (under the rear seat, I guess), so the pump runs continuously.
Iqy7861
22
12 October 2015 09:21 AM
ossett2k2
15
23 September 2015 09:11 AM
ossett2k2
9
13 September 2015 09:35 AM
blackandz
12 September 2015 07:01 PM
alcazar
Other Marques
9
09 September 2015 05:42 PM
Quick Reply: How to siphon petrol out of a car?
