Putting a complete STI engine into a WRX, what is needed?
Old 22 June 2011, 07:07 PM
wotagr8bigchief
wotagr8bigchief's Avatar
Default Putting a complete STI engine into a WRX, what is needed?
Having looked into the cost of re-building either of my engines I am looking to buy a complete STI engine that has had a recent rebuild to put into my WRX, I have found one at the right price but need to know if it will actually go in and run! The engine is out of a 95 JDM STI and my WRX is a 93/94 version 1 WRX. The only thing that isn't coming with the engine is the inlet manifold, will I be able to use mine or do I need to buy an STi one? also will I need an STI ECU and if so from what version?? Any knowledge on doing this swap would be greatly appreciated. Cheers
Old 22 June 2011, 07:22 PM
my94wrx
my94wrx's Avatar
the engine will bolt straight in a run after you have swapped over the inlet the manifold, you will be fine running on the standard wrx ecu.
Old 22 June 2011, 07:28 PM
wotagr8bigchief
Thanks buddy thats good news, is there any power to be gained from using an STI inlet or is it the same as my WRX inlet but painted red? Same with the ECU, is there power to be gained from using an STI one?
Old 22 June 2011, 09:11 PM
djandyg
djandyg's Avatar
pretty sure u need to be running the STi ecu and the loom to go with it. STI has different turbo, injectors, clocks etc so i cant possibly see how u can run it on a WRX ecu as theyre totally different engines.
Old 22 June 2011, 09:31 PM
my94wrx
my94wrx's Avatar
i think you need to read up a little first, the early phase1 (version1 and2) wrx's and sti's were very similar engine wise and identical turbo and injectors, not a lot of difference in ecu, and clocks don't even matter, unless of course the sti clocks say sti, maybe that will stop them from working.
Old 22 June 2011, 09:45 PM
djandyg
djandyg's Avatar
oh i see fair enough, id always just assumed that the differences between STI and WRX were fairly significant across the board even with regards to older models - my bad
Old 22 June 2011, 10:12 PM
madscoob
madscoob's Avatar
sti will of had a z4 ecu and 440 injectors thats the only difference i think . the injectors will fit your fuel rails as will the ecu just plug n play engine differences are internals higher lift cams and i think larger valves . some expert will be along soon enough to tell all i expect ps both engines will of had td05 turbo the same , wiring loom the same unless ra with 5th injector . z4 ecu runs higher boost and slightly more ignition advance,
Old 22 June 2011, 10:38 PM
my94wrx
my94wrx's Avatar
no they both had 380cc injectors, the wrx ran the z4, maybe the cams were different but the valves were the same size
Old 22 June 2011, 10:45 PM
wotagr8bigchief
Thanks for the advice guys, I think im gona go with the rebuilt STI engine and take it from there. Hopefully it will still run ok on my ECU and injectors, then i can start to look at tweaking bits. Out of interest does anyone have experience with Greedy electronic boost control?? my car currently has it and ive been told I should be able to up the boost to about 1.1 without any problems. Is this true? and if so any idea to power expectations? only mods are no cat full stainless and a decent panel filter plus the STI engine.
Old 22 June 2011, 10:59 PM
madscoob
madscoob's Avatar
ok maybe ime wrong but y7 was ecu on my 93wrx now fitted with a z4
ebay 200622643958 z4
abay 190532218512 wrx classic
Old 22 June 2011, 11:03 PM
madscoob
madscoob's Avatar
1.1bar = 15.84 psi both z4 and y7 ecu have lower fuel cuts than that , you will need a polar performance chip to do that as it raises the fuel cut to 1.15bar 16.6psi
Nick71
21
20 September 2015 03:52 PM
bparkes007
11 September 2015 07:13 PM
badly done
Scotland
10 September 2015 08:17 PM
Scooby-Doo 2
Wheels And Tyres For Sale
09 September 2015 06:51 PM
Quick Reply: Putting a complete STI engine into a WRX, what is needed?
